Hello my name is Dragos and I want to share with you a problem that I have on one IRC 5 controller.My problem was that my robot show me on the teach pendant the message "Connecting to the robot controller" and remain like this that means is not loading the operating system.First of all I start to search on the internet this problem.I found some information about this problem and appear to be the boot sequence from the flash card that is on the main computer unit.So I start to search again how to make a boot sequence and I found something about making a clone of one flash card that I have already from another robot.So I start to try first with Norton Ghost was not working.Second with Acronis was not working and after two days I was in that point where I want to quit and to buy from ABB one flash card with the boot sequence but I try one more time with another software.This software is AOMEI Backuper and this one help me to resolve my problem.I hope this will help you If you have this kind of problem.
Bootable Flash Image for IRC 5 Robot 1600
DragosM -
May 28, 2015 at 10:41 AM -
Hi wondering if you give more detail how you managed to fix it
Did you remove the flash drive clone it to used flash drive then reinstall it
DOM_irc5Ghost/GHOST32.EXE and 2 more files3 files sent via WeTransfer, the simplest way to send your files around the worldwe.tl
ghost for irc5.
you must be sure your computer its working properly.
my problem was on computer power supply 24 v,
i changed with a normal ATX unit .
test the pendant on a diffrent robot,
god luck
