Company that I work for purchased Fanuc robot and wants to start removing burrs from drilled holes. The holes were made with CNC machine with 0,1mm accuracy. Can the program be made somehow in a way that I just declare starting point and then distance between holes to make the positioning more accurate? Or how should I go about doing the program in this situation?. The R-J2 we are using has no optional functions to use for mirroring for example.
