I could use a little help
Have an R30-B controller with Ethernet/IP Scanner option. Want to use an SMC air valve manifold with an EX260-SEN1 module. I set up the Fanuc Scan List per the vendor-supplied parameters and verified them against the ex260_sen1_24_v21.eds file just to be sure. The robot returns error "PRIO 358 EtherNet/IP FwdOpen Fail (0x100)". Documentation defines this as "Connection in Use or Duplicate Forward Open".
Robot IP address is 192.168.0.241. SMC is currently set for 192.168.0.101. Valve is plugged directly into Port 2 of the controller with no other devices. Cable has been tested.
Does anyone have any ideas what might be the problem?
