KR C2 WinXP Embedded System wanted! HELP!!!
  • Mike.min
  • May 21, 2015 at 2:23 PM
  • Mike.min
    Hello, everyone. I am troubled with a KR C2 Edition problem which is that my hard drive does not work. So, I buy a new hard drive which the storage is 20G. Unfortunately, I did not make the WinXP Embedded of KR C2 back up. So, I need some one's help who can give me the system. Then I could re-install it. Anyone's is appreciated! Thanks!
    The KRC version is V5.4.14!
    SkyeFire
    1,052
    9,428
    • May 22, 2015 at 3:00 PM
    You can probably still get this from KUKA service. You'll need to provide them with the serial number of your KRC2 to ensure that you get the correct version.
  • Mike.min
    • May 25, 2015 at 5:23 AM
    Quote from SkyeFire
    Thanks for your reply. I asked KUKA Shanghai for help. They told me I had to buy hard drive from them. And it is too expensive. I have a document about the window xp, but I do not know how to use it.
    Images
      • 24.99 kB
      • 1,346 × 289
      • 40
    Files
    QQ截图20150525112140.png_thumb 3.72 kB – 30 Downloads
  • Jonson
    211
    • May 25, 2015 at 7:15 AM
    You can find a robot with C2 controller which is the same system version and hard moudle, and then backup it as image using ghost. I think restore the image to your robot controller will be OK. If necessary, you can setup a KSS.
    SkyeFire
    1,052
    9,428
    • May 26, 2015 at 3:57 PM
    Yes, I've done that in the past. It may still be necessary to fix certain items, like Windows IP addresses, but in general it should work fine. Image the entire hard drive, then restore an Archive for the robot being repaired.
    KUKA should be able to provide the Windows installer CD, regardless of whether the hard drive was purchased from them. They won't warranty the non-KUKA hard drive, but any KRC2 is going to be out from under warranty anyway....
  • Mike.min
    • May 30, 2015 at 1:40 PM
    Quote from Jonson
    Thanks for your help. It is really not easy to do that. Anyway If I find one, is it still to change the file like mada to adjust to my robot? Or else just re-install the KSS?
  • Jonson
    211
    • May 31, 2015 at 3:45 PM
    I think files what you have mentioned is easy for you, you can ask KUKA service for those files if you can provide your robot's model number.KUKA will tell you how to backup and how to restore.
    SkyeFire
    1,052
    9,428
    • June 1, 2015 at 12:02 AM
    Quote from Mike.min
    It's not hard, assuming you made a good Archive of this robot before it failed.
