How to copy generated .src/.dat to KRC1 and run them?
  • x9tech
  • April 27, 2015 at 11:29 PM
  • x9tech
    99
    I am generating a .src and .dat file on a PC and transferring it over a file share to a KRC1 controller - however, on the TP the program appears with a text file icon and is not selectable.
    Why is this, and how do I get it to compile and become a runnable program?
    Also, once that's solved, if I update the files over the file share, what's required for the changes to take effect?
    panic mode
    1,278
    13,079
    • April 28, 2015 at 12:12 AM
    not sure about KRC1 but in general - if you want controller to recognize program modules, you need to bring them in using kuka HMI and not windows explorer...
  • x9tech
    99
    • April 28, 2015 at 12:14 AM
    Once they are recognized, can they be updated remotely?
    Sent from my iPhone using Tapatalk
    panic mode
    1,278
    13,079
    • April 29, 2015 at 3:27 AM
    for files to be recognized as program modules, they need to be compiled - otherwise they will appear as text files.
    if they have right extensions and structure, they will get compiled when you copy them from shared folder or disc into ramdrive (KRC:\)
  • x9tech
    99
    • April 29, 2015 at 5:10 AM
    I've gotten into a decent workflow of copying to a folder on C:\ and then using the HMI to copy/paste the files, it's a little tedious for making touchups over and over but it works.
Users Viewing This Thread
  • 1 Guest
