If developed a library using the EthernetKRL and UserTech. that library provide some function for communication with other sensors
Is it possible to make a installer that user could via smartpad menu to install it ? what have to prepare?
Depends on how fancy you want to get. If you have the user install EKI and UserTech manually first, then your installer might only need to copy files into the correct directories on the C drive, and then trigger a Cold Boot. If you want your installer to modify pre-existing system files, that gets harder. And if you want your installer to show up in the Pendant's "New Software" menu, well, that I have no clue.
