Has anyone gone through the process of communicating a UR with a Fanuc Machining Center?? If so, can you explain how this is done?
Communicating between a UR and a Fanuc Machining Center
cottingham.christopher -
March 6, 2015 at 5:43 PM -
It should be similar to most CNC machines, it should only require a few digital I/O's. I would recommend hard-wiring the two together using digital signals. As far as I can tell, it shouldn't be difficult setting up communication to a Fanuc CNC. Most installations with robots and CNC machines, are usually controlled via digital I/Os. Fanuc CNC distributors or usually the machine operators have knowledge of the machine program, how it is organized, which signals are required/available, etc.The important thing is to figure out which signals to use, what order to set them, etc. Hope this helps you get started!
I connected a Mazak CNC (has a Mitsubishi control). I 'd definitely recommend you get the customer to buy the robot interface for the Fanuc controller.
It exposes all the I/O you'd need (such as E-stop, axis inhibit, auto-door open/close) and some other functions that protect the robot from any unwanted move (axis or door or spindle).
Not sure how much it would cost but expect between US$ 2,400 (for a current Haas CNC) to $8,000 for a 10 yr old Mazak CNC. Plus the factory tech to install it.
It also comes with a bunch of extra M-codes (typically 4 input, 4 output, at least) and associated relays that allow you to program the robot call via M-codes. Bi-directional communication via NC program. Again, makes your life a lot easier.
Some CNCs have spare M-codes that trigger relays but usually not often.It makes your life a lot easier!
And it adds safety factors that you cannot get through hardwiring.
I would be very reluctant to connect a robot w/o that interface.
I sell CNC programming software so I see a lot of CNC, and they are not simple machines!Add automatic door (you may be able to get away with either building your own automatic door opener-like i did) unless the robot can open the door by itself.
The robot can also press buttons, such as 'cycle start', 'chuck open/close' (on a lathe).
You'll need some sort of automatic workholding device: on a lathe, usually a hydraulic chuck if so equipped, on a mill, that's a whole other story.It is not easy.
You'll see on the UR youtube channel, the CNC tending applications, there's a pneumatic vise on the mills or a hydraulic chuck on the lathes.
There's also a door-opener (robot or internal pneumatic cylinder).
Hope this helps. -
Hi Everyone,
I had recently made interfacing with Fanuc Machine.
We need following Digital I/O for Machine Tending App. & some M codes need to enter into machine for Manual & robot options & double acting pneumatic cylinder for opening & closing the doors.
I/O LIST FOR MACHINE & ROBOT INTERFACING
Signal from M/C To Robot
Sr No
1 M/C_ ChuckClamp
2 M/C_ ChuckDeclamp
3 M/C_ DoorOpen
4 M/C_ Ready
5 M/C_ Alarm
6 M/C_0 Volts
Signal From Robot To M/C
Sr No
1 M/C_ ChuckClamp
2 M/C_ ChuckDeClamp
3 M/C_ CycleStart
4 Robot_0 Volts
Note:- Ready means healthy Condition of M/C for Robot
Note:- Alarm means Unhealthy Condition of M/C for Robot -
Thanks Shale, Was this a Fanuc Robodrill? do you have a video by any chance of the UR working with this machine if it's a robodrill. Thanks again.
Does anybody have more information on interfacing UR to Danica machines?
