I need to change current KUKA robot's IP addresses.
We have two KR-16 with KRC-2 pendants.
One of KR-16 is mated with Cognex vision camera using KUKA vision software.
There are numerous IP addresses on PLCs, valve banks, other equipments including AB PV+.
I think I can manage to change others but not quite sure on changes on robots and vision software.
Change of IP addresses on old robot
edkorea -
February 12, 2015 at 4:26 PM -
Log in as Expert or higher and use CTRL-ESC to get the Windows XP "start" menu. Go to the Control Panel and look at the network interfaces. There will be at least two.
The interface named "VxWIN RTCC Shared Memory Network Driver" has an IP address of 192.168.1.2 (or something very similar). NEVER TAMPER WITH THIS INTERFACE. It is a "virtual" network internal to the robot.
The other network interface could have any of several names, depending on the generation of your KRC2. But it shouldn't matter -- you can change that one all you like. Change it to match what you need. One caveat: you cannot set it to 192.168.anything -- that IP range is reserved for the internal network, and setting the external network to that IP range will cause conflicts.
Thanks for your reply.
This is for VPN connection to OEM and will be changed to 10.41.xxx.xxx.
