I accidentally changed the Realtime OS Virtual Host network adapter IP, but now I set it back to the original one: 192.168.0.1
As I read in another topic here, I unplugged the smartPad and I am working now with an external monitor and keyborad/mouse.
The robot booting gets stuck at the point "Waiting for KRC Connection", shuts down the "smartHMI" interface and shows to the Windows desktop. From here, and from the smartPad if I plug it, I can ping to the 192.168.0.1 and 192.160.8.2 addresses.
I executed the KRC Diag application and this error message shows up:
12:51:52 C:/ws/S_QA_DEAU1SVR12PT-06_Rel82KRC_SR/kca_Grundsystem/PC/BSP/kukaLib/ConnectionLib/ConnectionConfig.cpp:143 Error opening parse file Config/System/Common/ConnectionLib.xml -3670019- S_dosFsLib_FILE_NOT_FOUND
12:51:52 ERROR tSysBoot 12:51:52.475 : 'SysBoot': Nameserver Port could not be get from config File! Using default Port 23456
12:51:52 ERROR tSysBoot 12:51:52.475 : 'SysBoot': Nameserver Address could not be get from config File! Using default IP (loopback)
12:51:52 ERROR tSysBoot 12:51:52.475 : Could not get nameserver timeout from the config file. Set it to no timeout
12:51:52 ERROR tSysBoot 12:51:52.475 : ERROR while connecting to the nameserver
I confirmed that the file Config/System/Common/ConnectionLib.xml exists.
Does anyone know a possible solution to avoid reinstalling? Thanks!
KRC Version: KR C SR, V8.2.3, Build 22.
