With no one touching the pendant, on KRC4, the KRC programming is running (Robot is moving) but the screen is minimized.
Can anyone know how to maximize back so I can see the programming lines?
I've tried to run "krcstart.ext' again but no use.
KRC4. KRC is running but minimized.
edkorea -
January 29, 2015 at 5:42 PM -
If the SmartHMI is minimized, you should simply be able to touch the icon in the status bar to bring it back. Is the SmartHMI visible in the status bar? It looks like a grey square with the silhouette of a robot on it.
Have you tried a cold boot?
No gray icon on system tray.
Also, when cold boot, it comes back, but goes away after 1 hour or so, of inactivity.
Yes, I check the screensaver and nothing setup.
When i switch the key (to change to T1), the KRC screen comes back, but after I make change, it minimize again.
I'm going down to machine and see if I can get some clear picture of screen.
