I would like to know is it possible to connect a siemens panel ( for example "SIMATIC HMI TP1200 COMFORT" ) to KRC4 controller ? Which interface is prefer to used ?
Panel <--> KRC4,
not via a PLC CPU
Thank you!
The following table shows the PLCs and the communication drivers which can be used with
the HMI devices. PLC HMI devices
SIMATIC S7-1200 Yes
SIMATIC S7-300/400 Yes
SIMATIC S7-200 Yes
SIMATIC HTTP protocol Yes
OPC 1 Yes
OPC UA Yes
Allen-Bradley EtherNet/IP Yes
Allen-Bradley DF1 Yes 2, 3
Mitsubishi MC TCP/IP Yes
Mitsubishi FX Yes 3
Modicon Modbus TCP/IP Yes
Modicon Modbus RTU Yes 3
Omron Hostlink Yes 3
1 OPC-XML DA Server
2 Direct communication with PLC 5, with the KF2 module, otherwise approved only via the optional
converter RS422-RS232, order number 6AV6 671-8XE00-0AX0.
3 "PROFINET IO Enabled" must be disabled.
