Hi everyone,
Im experimenting problems with INI file as attached and DSE. (pictures attached)
Robot dont move neither in manual mode.
INI Files seen to be ok.
Many thanks,
Eugenoio Carvalho
Hi everyone,
Many thanks,
Eugenoio Carvalho
check if DSE board is connected (seated correctly) on MFC card. if that does not help, replace DSE board.
Hi panic Mode,
The dse board already been substitute.
Thanks,
Eugenio Carvalho
then problem (poor connection for example) may be on MFC side. did you also try replacing MFC?
No, at the moment i dont have a second mfc card.
Thanks,
Eugenio
