I can't restore archive file. When I try restore file, appear message about restore in progres, but this message can stay very long time (I waited 2 hours) but archive don't restore. Archiving process is normal. KR C4, KSS V8.3.5 Hf02, Win7. Please, help me.
Can't restore archive
Andy_rus -
November 5, 2014 at 11:37 AM -
can you post archive?
here archive
on the first look everything looks ok. then few things appear... first of all this is an old archive (more than 2 months old) and if it is not, then time and date is not set correctly. also turns out log file KrcLogU.evt is corrupt. if it is excluded, there are remaining 45332 messages, and last cold start was message 43000ish (months before archive was made). also robot was replaced (serial number used to be 687356, now it is 630094) and your KLIConfig.xml version is 8.2. project ILOT2_C1_CHG is not complete, when compared to work project it shows that it does not have XML files for axes A1-A5 (under Common\Mada\NGAxis) and fails to compile.
tips:
1. check manual on how to use Restore archive function (hint: it is not just connecting usb stick, it involves login, coldstart etc.)
2. try good old cold start with 'reload files' now and then or at least when there is a problem
3. you may want to get the project fixed, when something is missing, controller tries to use files from base project (as long as base project is still intact). -
I restored all the files from the archive manually, and after that the system works.
Old archives don't restore. Today I'm tried restore archive from 2-nd September, attempt failed. And if take yesterday's archive, restore procedure ok. Have two question: 1) how long time pass before archive becomes old? 2)How restore old archive?
how old is old?
for me archive becomes "old" when you change something on a robot (add, delete or modify program, teach point, change settings, comments i/o descriptions etc.). but that should have no impact on ability to restore...
restoring old archive can be an issue if software or hardware changed (newer kss for example).
if robot name was changed, renaming archive to match new name should do the trick.
Difference between old and new archive, I try restore, only robot trajectory. Hardware, software, system, ... don't changed.
