hi
Is it possible use do in if instruction as blow :
IF do1=1 THEN
WaitTime 1.5;
endif
if it is possible How can i use ?
thanks
ELECOMP -
September 22, 2014 at 4:47 PM -
hi
you should use like this
IF Doutput(do1)=1 THENthanks
Actually both style is not correct, you can not use "if do1=1 then", It will be error message if you use like this.
Aylar's answer is correct, you have to use "DOutput" command.
thanks for replays
I tested both command and just IF Doutput(do1)=1 command was true . -
have you tried 'compactIF' ??
Hi megatooL
I tested for compactIF . But it's wrong .
thanks
