Hello all,
I'd like to be able to use pointers to digital inputs and digital outputs, is it possible somehow?
Thank you all!
Hello all,
Thank you all!
Yes I knew that, but I would like to be able to use a more advanced method like reference by name, an alias as in abb or a pointer.
We make similar machines but usually i/os are not in the same order then I would need to reassign all the indexes.
I can use this, at least for what I asked about.
So, even I'd love something different, thank you.
can you use signals?
As Panic says, you can use SIGNAL declarations:
SIGNAL iToolChangerUnlocked $IN[101]
SIGNAL oToolChangerUnlock $OUT [101]
SIGNAL i8bitsFromPLC $IN[109] TO $IN[116]
After that, the names are "pointers" to that particular I/O.
If your problem is that different robots use different $OUT/$IN indices for the same signals, my first suggestion is to beat the controls hardware designers until they perform better. Failing that, I tend to use a "Global Definer" module, which contains INT variables for the correct $IN/$OUT indices, and has executable KRL code in the .SRC file unique to each robot that "sets" those variables to the correct values.
