If we want develop PC application using XML communicates with KRC4 (KSS8.2 or KSS8.3), I am not sure the EKX package could works within the OfficeLite (for KSS8.2 or KSS8.3)?
Anybody have tested it? please give a feedback, thanks!
Could the Ethernet KRL XML works in OfficeLite? ( yes, it does)
irobot -
July 21, 2014 at 6:26 AM -
It should. OfficeLite is just a virtual maschine. I've never tried EKI in office lite, but there is no problem with OPC XML-DA, so I'm sure that EKI will also work.
I know that RSI will not work in OL -- in fact, it won't even install (well, as of RSI 2.x and KSS 5.6). EKX... hm, it might. You would definitely have to use the KUKA-Router program and direct traffic to the RTACC network driver, however. But that should work under OL.
That said, I have to admit I've never tried it, so.... -
It should. OfficeLite is just a virtual maschine. I've never tried EKI in office lite, but there is no problem with OPC XML-DA, so I'm sure that EKI will also work.YES, the OPC XML-DA Works.
As Skyefire wrote, you need the KUKA router software. I have tried this and it works inside OL 8.3 and 8.2.
It's very luck yesterday I found the thread about this
Quote
Using RSI Monitor through the KUKA Router
https://www.robot-forum.com/robotforum/kuk…25681/#msg25681I will try later
great!
the five demo example all works ok! thanks all!
