Hi, I'm working with krc4, i built a project and every thing is perfect. But when i download the project to other similar robot
and after i taught the bases for the new robot . when i start simulating the program i got an error( i couldn't reach to the points that i copied from the first robot) because of status and turn.
The robots are the same and are for the same purpose, so how can overcome this issue?
I don't want to teach the points again,
KRC4(#KR150R2700 EXTRA C4 FLR) status and turn
bayeh6 -
July 3, 2014 at 5:32 AM -
Probably you do not have the same setup for both robots. For status and turn related issues I would diff R1/$machine.dat and System/$config.dat of both robots using a diff tool of your own choosing. I personally use kdiff3 (http://kdiff3.sourceforge.net/) for jobs like these. $machine.dat shows the kinematic setup of the robot including how they are mounted in $world. $config.dat has info on tools and bases.
Fubini
Or, he could just remove Status and Turn from the E6POS variable in the .dat file and the robot will sort out the rest itself
any other solutions. To omit the S and T for each point , i've so many points it'll take time
thanks
One small trick you can _SOMETIMES_ use when you have problems with status/turn is to change the motion to a linear, run there and touchup, then change it to ptp, as status and turn are only considered in constant path movements.
Also, if you approach a singularity during the linear motion you will probably get an unwanted movement with much reorientation of the wrist axes during the ptp motion.
