Hello, we have a krc2 controller, recently I plan to make a image of HDD of kuka pc.
As i do not have the kuka recovery stick, Is there any ways that i can make the image of HDD?
PS: in my opinion, i decide to pull out the hard disk from KRC and make the image in other pc, but i think it is not convenient.
Anybody have suggestion?
about image of KUKA HDD
bobby8464167 -
July 2, 2014 at 8:41 AM -
You can boot a KRC2 from a bootable CD. Depending on the BIOS version, you may be able to set the BIOS boot order permanently, or you may have to plug in a keyboard and catch the BIOS startup menu as it flashes by during boot.
Once you can get the KRC2 to boot to CD, I've had good luck using basic Linux boot CDs (using dd or ddrescue), and CloneZilla. A sufficiently large USB key should be able to contain the entire hard drive (you want to get both C: and D:), although back in the old days before high-capacity thumb drives I used to plug a portable USB hard drive in. Or if you have a network and remote network share, that'll work too.
Pleasse write me a mail.
Regards,
http://www.robottr.com -
You can boot a KRC2 from a bootable CD. Depending on the BIOS version, you may be able to set the BIOS boot order permanently, or you may have to plug in a keyboard and catch the BIOS startup menu as it flashes by during boot.Once you can get the KRC2 to boot to CD, I've had good luck using basic Linux boot CDs (using dd or ddrescue), and CloneZilla. A sufficiently large USB key should be able to contain the entire hard drive (you want to get both C: and D:), although back in the old days before high-capacity thumb drives I used to plug a portable USB hard drive in. Or if you have a network and remote network share, that'll work too.
SkyeFire, many thanks! I will try it!
