Is it posible to lock the screen.
so if you press something notting happends when key is removed.
but you still see the active program.
somebody experience with this.
Do you get any message on the smartpad?
Have you robot logbook ?
Regards,
http://www.robottr.com
Have you plugged in an external monitor by chance ?
I think he is asking if he can start a program up, remove the key THEN lock the pendant so you can't do anything unless you have a password.
Remove the smart pad plug in ext monitor
Can you do that on KRC4, because when I've tried it in the past I just get Windows displayed at what I think was a logon screen or something.
You'd think you worked for KUKA or something!
Remove smart pad plug in monitor
If you boot up the controller without the smartpad connected it will automatically log in "on your monitor".
Otherwise you need to enter a password, which can be found if you search around here.
You can also remove the key when you are in external automatic, then you can't change anything.
Yes this is what i mean.
Or how can you change the password from operator,expert,safety expert and safety recovery its standard kuka but i want to change this
Can some one help
To change the password for each user mode, at the log in screen there should be a change password button. Enter the current password then your new password.
