I would like to know if there's a way to modify the vision tool properties once created using Karel commands. My problem is that I have created a vision program to recognize a specific pattern. If it is not found, I would like to perform an other recognization but with lower tolerances. For example, I could change the Score Threshold from 75% to 50%. Is there a way to do that ? Otherwise, I will have to create multiple vision programs with the same pattern but with different parameters and call them if nothing is found, wich is not the best way to go...
Thank you,
Steven
