JZNC-YIU02-E (I/O) manual1
  • mhasman
  • May 9, 2014 at 8:52 PM
  • mhasman
    82
    Good Afternoon Guys!
    Someone here could send me the manual signal connections to a DX100 controller, more precisely the signal plate (JZNC-YIU02-E), I am unable to find in my manuals, the output card there is a number 8235022 (CN306) and input 8235020 board (CN307), someone could help me or provide the manual with the connections?
    :help:
  • Pcarbines
    292
    • May 9, 2014 at 11:26 PM
    Hi , at the rear of the DX100 "Instructions " manual , section 13 you will find the paper work for the I/O connections , applicable to the "arc welding " , "handling", "general " & "spot welding" plus the use/description.
    [Y1U01-E (NPN ) Y1U02-E (PNP) I believe]
    However, for some reason only known too Yaskawa. They don't mark the connector strips in the same way ie. CN 306>>309 (Y1U02 module ) become X *** >> X***(connectors strips)
    Because your X ***. Markings might not match others , trace the cables from the connectors back to the module to get correct allocation.
    If you cannot find 4 of the. X*** connectors strips on the controller door (usually) , it might be your DX was purchased (optional) without them.
    Send me a pm with your email address if you don't have this standard manual.
    Edited once, last by Pcarbines (May 10, 2014 at 12:22 AM).
  • mhasman
    82
    • May 10, 2014 at 4:21 PM
    ok, thanks for answer!
  • postek
    33
    • July 10, 2023 at 9:17 PM
    https://www.motoman.com/en-us/service-…f4%2f178956-1CD
    JZNC-YIU02-E Board for I/O Expansion for European Standards
