After replacing batteries I moved the S motor to 0 and shut the robot off and started to reset the encoders placed jumper wire in 8 and 12 on S waited a few min and removed jumper and plugged S back in. After powering robot up I recieved MAKE ABS DATA ERROR 08 0000_0010 It will not let me reset it everything is locked up S servo pack is flashing a red light could anybody tell me what I need to do to correct this issue I know longer have manuals on ERC cells.
ERC K6SB Make ABS DATA
Clearfork -
April 8, 2014 at 2:09 AM -
Don't understand. Why did you try to reset the encoder "after" replacing the battery. The code you gave us is not complete, don't know if it's the S axis or another axis that needs to be fixed. Are you sure you are shorting pins 8 and 12 (not 1 and 5, or 4 and 8 or 9 and 5?) sometimes you have to leave the jumper on overnight and other times you have to replace the motor.
see attached Pages , there is only one way to "Home Position Calibrate" an ERC
"By the Book".
Please remember you are working with 23+ year electronics , many of the PCB
"components" are no longer even manufactured.
