1.If i want to creat i/f panel in yaskawa . How to do that please provide software name . Other then yaskawa copyright . ... ?
2. Please provide the name of variable for overdrive . ?
3. How to select between path oriented robot and cycle time oriented robot from where we get option to choose like fanuc?
4. How to get tip wear value So that we can move it to plc?
5.
how to creat interface panel for robot? please provide name of software.?
lovleen90 -
March 11, 2014 at 5:43 AM -
1.If i want to creat i/f panel in yaskawa . How to do that please provide software name . Other then yaskawa copyright . ... ?IF Panel is done on the pendant. You can also write the file in any text editor as long as you know the format. This is all based on that IF Panel is turned on your controller.
Tip wear compensation is done with the SVGUNCL instruction and using the TWC tag. There is more information with the TWC tag as to if pressing against a board or tips pressing against each other.
5. -
Please provide the name of the file for i/f panel....i cheked the backup but not able to find the file. So that i can edit text file.
And how to form the graphics from tp. I dont think we can creat i/f directly from tp.
lovleen90
Do you have the IFpanel option ? if you have it thenthe name IFPANEL.DAT
yes, you can create it directlyuse the SEARCH button of the forum, there are examples
Yup i have ifpanel.dat.. in backup..... but i try to open it through notepad and orangeediter .... they are useless.... plz can u tell me ... software name which compatible with it..
Fed up ... having i/f panel option still not able to find how to create i/f panel ... plz need help provide some.... hints or document on this. Provide step by step procedure to do that....
Press SYSTEM INFO button
Press I/F PANEL SETUP buttonDo you see the setup screen ? yes ? then now do a search in the forum for I/F and look for a post that I put with programs attachments and pictures
