I have a problem to load the file into my controller. I just can save the file but can't load all marked data. Anyone can help?
load BATCH-CMOS file SK6
jon.vito82 -
February 5, 2014 at 6:01 AM -
Hi ,
the blacked squares show that these files cannot be loaded due to the security level you are in
And "Posting the Yaskawa codes is not permitted on this forum". -
If it's an MRC, go into the customer protected area (CUST - MORE - ORG) and type in your password (00000000). If you press MORE a couple of times, you will find an FDD option that allows you to back up more options.
If it's an XRC, switch to Management mode (TOP MENU - AREA KEY - SECURITY). You should then have more backup options.
Not sure which you have, you say it's an SK6 but the picture is of an XRC pendant. So thought I'd be safe and give instructions for both.
