Is there a way to continuously map a system variable, which holds an integer, onto a analog or digital output (or even a numeric register)?
Mapping System Variables onto Outputs
oneslyfox -
December 13, 2013 at 4:42 PM -
Hi
My answer for "continuosly map" will be background
Are you looking for something like ?
R[3]=5 loads value 5 into register 3
GO[1]=R[3] loads register 3 value into group of output 1. The result will be a value 5 in the group of outputsSimilar for inputs
Well more specifically I'd like:
AO[1] = $TCPPSPEED.$speed
I don't see why not. You can do it also for boolean system variables. False/true are referred as 0/1.
However, you cannot read the string system variables, even into a string register. -
Here is a line out of one of my BGlogic programs. Works great.
: GO[3:shelf_num_remove_ack]=R[10:shelf_num_remove] ;If you use BGLogic to transfer critical information I would also recommend setting up a heartbeat signal from the PLC and echoing it in your BGLogic program:
18: ;
19: R[15]=DI[84:BGLogic_Heartbeat] ;
20: DO[84:BGLogic_Heartbeat]=R[15] ;
21: ; -
18: ;
21: ;
This has nothing with the topic subject, which is system variables. -
Yes, sorry you are right.
3: ;
4: !step mode to PLC ;
5: DO[23:Step Mode]=($SSR.$singlestep) ;
6: ; -
18: ;
21: ;Our biggest problem is we don't have BG Logic on our robot. Is there any other way to do it without BGLogic?
Of course there is. Its just so many are fans of the BGLOGIC stuff that I think they forget not all customers purchase this option.
Just do it as a short TPE program that loops over and over or do it in Karel in the same fashion.
SO..
at the top of your 'main' program, simply do a RUN 'program name' and it will run in the background setting your output while your main foreground program executes like it should. You don't want to use the CALL , use the RUN command.
Hope this helps..
Of course there is. Its just so many are fans of the BGLOGIC stuff that I think they forget not all customers purchase this option.Just do it as a short TPE program that loops over and over or do it in Karel in the same fashion.
SO..
Hope this helps..
It works! Ah! Thank you, thank you, thank you.
