Hi. I have a troublem with MRC SK6 Error 200...Please help me.thanks
help with error of Mrc sk6
GWrobo -
December 12, 2013 at 5:07 AM -
I have resolve this troublem by i go to Maint.mode and choose MIFO1 Board.After turn off, i turn on robot then program start normal, Last line robot display CMOS.... but i have a new problem. When i turn on servo robot display error 4960. I have lost the program?? please help me. Thanks
By choosing the MIF01 board in maintenance mode you have initialized the MIF01 card. So yes, you have blown away the jobs, settings... If you have a full backup you can load the CMOS file. If not you may have to call Motoman to come in and initialize the system and get your robot going, then re-teach all your jobs.
Thanks robodoc!
Now, i don't have a full Backup. But i have a robot sk6 other. It's normal. May I can create a backup of the other robots and then transferred this robot?
If possible. Please help me creat of backup for this. -
As long as your other SK6 is the same (same I/O, same application, same welder...) then yes you can make a backup of that robot and load it into the broken robot. After you have loaded the data into this robot you will have to re-calibrate the ABSO data and delete the jobs.
