help for rj controler arcmate 120
  • GWrobo
  • December 4, 2013 at 3:12 AM
  • GWrobo
    76
    When i calibrate robot, after turn on robot, i move robot in Joint'coordinate then normal buy in XYZ'coordinate then robot display error "MOTN–023 STOP In singularity".I think can i calip robot not correct, I have try calip but.... Please help me...Thanks :help:
    Edited once, last by GWrobotic (December 4, 2013 at 3:53 AM).
  • GWrobo
    76
    • December 4, 2013 at 3:51 AM
    for calip robot i have do these step...please help me
    Press MENUS.
    3 Select SYSTEM.
    4 Press F1, [TYPE].
    5 Select Master/Cal.
    If Master/Cal is not listed on the [TYPE] menu, do the following;
    otherwise, continue to Step 6.
    a Select VARIABLE from the [TYPE] menu.
    b Move the cursor to $MASTER_ENB.
    c Press the numeric key “1”and then press ENTER on the teach
    pendant.
    d Press F1, [TYPE].
    e Select Master/Cal
    Select Zero Position Master.
    7 Press F4, YES. Mastering will be performed automatically.
    8 Select Calibrate.
    9 Press F4, YES.
    10Perform a cold start.
    a Turn off the robot.
    b Press and continue pressing the SHIFT and RESET key on the
    teach pendant.
    c While still pressing SHIFT and RESET, press the ON button on
    the operator panel.
  • kluk-kluk
    53
    5
    300
    • December 4, 2013 at 11:44 AM
    Luckily it ihas nothing to do with the mastering.
    You will get that error when two axis are in line with eachother, (most of the time axis 4 and 6) the robot can't calculate wich axis to move, and it stops.
    Reteach the points with a slight angle between the axis involved, and the problem pops away.
    There is a variable $PARAM_GROUP[1].$SNGLRTY_STP, when changed to FALSE, the robot will ignore the error, but movement can be unpredictable in that case.
    You will have to cold-start to change.
  • GWrobo
    76
    • December 4, 2013 at 6:35 PM
    Thanks kluk-kluk for share.I will change $PARAM_GROUP[1].$SNGLRTY_STP is FAULT. but I have a question, You say" Reteach the points with a slight angle between the axis involved" i don't understand. Can you explain further and I have a question when i calibrated finish then $MASTER_ENB auto set to "0" or still set "1".
  • GWrobo
    76
    • December 5, 2013 at 12:27 PM
    hi thanks Kluk-kluk. I have resolve the problem.
  • kluk-kluk
    53
    5
    300
    • December 5, 2013 at 8:58 PM
    Great to hear that.
    Glad to be of any help !
