Hi
i had english version,i like to take out F.ROM on MM14 board to load into by adaptor.
I have not FDD software , i can not make to back up all PRM file system.?
if must be to buy FDD from Motoman is so i can't .( not much money )
change english language for ERC,MRC
anthony -
December 1, 2013 at 12:50 PM -
The ROM chips you can remove from the MM14 board are the system software (like windows XP, or Vista. In your case Windows 3.1). The chips you can not remove (soldered on to board) have all the jobs, files, parameters... However, if you remove these chips from the board they will loos there memory. The capacitor on this board hold the chip on and hold the memory. Once removed, poof, no more data.
By the way, if you remove the proms from the sockets and try and read them all you will get is HEX data. Nothing you can read or do anything with.
thanks so much Robodoc.about MRC ? can you help me?
MRC is the worst for software. You need a matching set of MMM02 and MMM04 boards that have the system ROM and language options (they are made for a robot size so not any set will do) and you need the matching proms for the MIF01 and SMV01/02 cards.
Thanks Robodoc.now i can undestanded more about MRC.
Autech,
I keep telling you it is not a parameter. The problem you are having is with the welder, how it is connected and the CIO. There MUST be a arc established signal from the welder connected to the analog card. You said it's 2173. I would have to look at some very old manuals it confirm this, but you have also said it's MRC and MRCII. There are big differences between these controllers. If there is a Arc established connection this input (2173?) would come on only when the welder sends the arc established signal.
If you really need to get this running, the best way is to have someone who knows old Motoman robots come and see you. Trying to fix this through email and the robot forum will take a very long time.
thanks Robodoc.i usually a ERC ,MRC,MRCII to used the same welder ,same cable welder control.may be it,s the same CI/O.
my friends have much experience about Motoman but don't talk to anyone.he said that's secret of him.
i expect at here to help.
