What do the parameter path return
Region do?.
IRC5 system path return region
jocke75 -
November 18, 2013 at 6:52 PM -
This is a parameter that define the distance possible to the robot can return to the movement without special treatment. On teach mode and automatic mode.
See the attached
the parameter you can set is they to specify how far off the tcp is from last executed path or point?.
I have a multitasking system with two welding robots in each task and one positioner station i another task
sometimes a get the alarm 50287.
can i make the system less sensitive to do alarm by editing the parameters?. -
the parameter is about path.
Ok, if you have this error and works with 2 robots and one positioner station, there are some points to have attention.
I supposed that your system works with semi-coordinated movements, then it uses instruction WaitSyncTask, finepoints, actunit etc...
See the attached. Mainly 6.5.3 there exist important points.
Is very important to ensure that the considerations and limitations are correctly done.
