I have pana robot AW 8006. When I turn on servo robot error in my picture. Please help me resolve this troublem. Thanks.
help Pana AW8006 error
GWrobo -
November 11, 2013 at 8:08 AM -
I have change error to English. It's mean ENCODER HOLDING VOLGATE ABNORMALITY RT. i have change Cable motor and encoder RT to UA but error not change. I also change SERVOPACK of RT & RW by a Servopack other but error not change. If anyone has encountered this error can share with me...Thanks
Check or replace encoder battery, and reset encoder.
Do not change encoder cable, when you disconnect the cable, maybe absolute data in encoder be lost and you will get an error message like the picture whenever press servo on.
AW8006 and aw05c use the same scheme to reset encoder, i think you know how to reset.
RT motor of AW8006 about 550W, RW is about 80W. If you change the servopack, it can lead the RW motor to be fired up.
I have check power 5v and battery 3.2V on encoder of motor RT. I also check battery on robot and battery on control cabinet. It still 3.6V. I just have not reser encoder. I will try tomorrow. I want to ask a question for reset encoder I will link reset wire and 0V wire of battery?
I don't remember exactly the pin number of reset pin.
The error relate to ENCODER, so, just check carefully encoder and specially the battery, don't need to check main battery or others.
REMEMBER THAT: if you disconnect the encoder cable of motor in some minutes (can be 30 minutes or sometimes just 1 second), you will get the error in picture because the encoder lost its absolute data. -
thanks for share. I have reset encoder RT but error not change and i also change cable motor and cable ancoder of motor RT by UA, FA. But error not change. I also check battery and change it by new battery but error not change. If anyone has encountered this error can share with me...Thanks
May i reset encoder not correct.... I don't have document for robot pana 8006. So please help me reset encoder, i must connection with any wire rope correctly.
Which pin (number and color) do you use to reset?.
Did you check the PG cable from controller to manipulator is tighten ? -
i use pin 10 and 16 ( black and gray stripes(GND) and gray(RST)). i have alo check PG cable from controller to manpulator It's normal.
I can't sure that 10 and 16 can be used to reset or not . In my case some year ago, I used others pin which i don't remember clearly now , they don't stand in same side of connector as 10&16 in your case.
USED PIN 13 AND 16 TO RESET ENCODER.
TURN OFF POWER + RESET IF NOT,
TURN ON POWER + RS -
hi Mr.closed. Thaks you for share.You say "uesed pin 13 and 16 to reset encoder" but Pin 13 is +5v and PIN 16 is RST. Can Two wires use to reset encoder??? Can you help me explain..
