Dear sir,
i need help form your side , how to run the robot without teach pendent
pl send the procedure.
Dear sir,
Maybe this is any help...
if you've robot with program tool handling or arc that you are need to read manual about UI or RSR/PNS. It was actual if you use a digital IO or in other situations KCL command & others method.
you can purchase a dummy plug from Fanuc to do this.
