Hello All,
Perhaps someone here can help me with the correct syntax I am looking for. I have a TP program that I have made to test the min and max torque values of each axis (preventative maintenance). At the end of this program I want to call a Karel program to copy the file 'Numreg.va' to the USB stick in the TP. I am used to KCL commands from working with some old P150s and reading through the R-30iA manual, it seems I would be able to get away with the simple code below in a .kl file but OLPCPro does not seem to like the syntax:
PROGRAM copynumreg
BEGIN
KCL>COPY MD:NUMREG.VA TO UT1:
END copynumreg
