Is there a way to get a hard copy print out of the position and external variable names and their values. I looked at VAR.DAT and VARNAME.DAT. I would like to tie these 2 together, possibly in an excel spread sheet. Thanks in advance.
variable print out
mike mitchell -
October 24, 2013 at 3:23 PM -
I have the exact same issue. I am working on a project which uses a very large number of addresses for I/O and data in over two dozen programs. I am looking for a tool where I can collect which addresses are used where so we can maintain and update the code.
Nothing official from Motoman unfortunately.
It is possible though, after all it is just a text editor.
RoboGuru
Thanks for your reply. The response I got from Motoman was "Make good back-ups" With multiple programmers in a Jobshop environment I am concerned that this info. will be written over.
Backups are your friend.
You can also enable a password mode such that every person is given a username, password and access rights. If you are the administrator you can assign your self MANAGERMENT mode privilideges and setup all others with operators.
Food for thought,
Rg
