while connecting a display to the KRC4 PC,after the reboot,the logon user name and password comes on.
does anyone know the password?
right now the user is administrator but even for a lower level user it would help.
otherwise there no option of connecting the display.
is there?
thanks,
KRC4 Administrator password
nuni -
August 20, 2013 at 4:24 AM -
You mean connecting an additional display?
What you are seeing is a RDP connection, it's the same when connecting remotely and using the SmartPad, although that sends the password to the PC automatically.
Use administrator and 68kuka1secpw59
thanks.
tried it.
it gets unlock for a second and then lockes again,asking for a password. -
If you remove the KCP before start up, you should be able to get into windows and set up an additional Administrator account.
From there you can shutdown, reconnect your KCP, power up, and log in with your new administrator account.
Hope that helps.
Great information, I just had an issue with a Tech Package messing up the log on process and I had no way out.
