Hi all,
I am looking through somebody elses program and it reads:
GETE TEMP_CALC_VAR_B PALLET_OFFSET[0] (3)
Can anybody tell me what the significance is of the zero in the square brackets?
PC
Hi all,
PC
this is with variable alias. it is possible that the variable is writen this way.
Hi Potis,
can you give us some info about 'variable alias'. Any manuals? It sounds interesting but I've never heard of it.
this command would be f.e.
GETE D000 P000 (3)
if the variable alias parameter is on then you can see on the jbi the name of the variable (D000 and P000) that you have declared in order to be easier to read. the parameter depends from the controller. when this parameter is activated when you insert a new instruction containing a variable a popup window will ask you if you want to use the variable alias. only problem is when you want to change the name of a variable you must turn off the parameter, change the name and then turn on again. which controller do you have NX or DX? i havent seen any manual for this.
The controller is an NX.
I checked the alias but there is definitely no [0] in there.
The variable PALLET_OFFSET is a position variable. It is actually P009. Does this make a difference?
Mystery unsolved...
For me the controller is a DX100.
Parameter for Variable Alias is S2C298 for NX. S2C396 for DX.
Parameter for IO Alias is S2C297 for NX. S2C395 for NX.
