Hi, can it be harmfull if you use a CIO.PRM from a MH6 on a MH20D?
Thanks....
Thanks....
Yes it can.
If you don't have a good understanding of these parameters then why would you even think about copying them into another system?
What are you trying to do?
RoboGuru
making robot cells to moulding machines (almost same precedure each time)
I have made several changes
conveyer start/stop upon foto cell,
sequence with easy start with only one button (servo ON, wait for servo ON, then EXternal start...)
and other changes...
I have tried to load the CIO into the other robot ............but with no luck (ERROR in program structure)
I ran a compare test of the files ...and they were completely different..
...so my gues is that it is not easy...
