We have recently bought some used KRC1 robots. So far the only way we can figure out how to cycle start a program is from the teach pendant. I really do not want to use the teach pendant with our production workers because they will brake them in no time. Where could I connect wires inside of the controller to put my own cycle start button? Thank you!
KRC1 Cycle Start Questions
tbrewton -
June 13, 2013 at 3:38 PM -
here is a picture of what the screen looks like
More details required.
What mode have you been running these robots in? AUT?
If you want to use EXT mode, you have to add external I/O. Do you have any I/O available on these robots?
If you have available hardware I/O to wire buttons to, you need to look at the Automatic External section of the Configuration manual (next door in the Manuals&Software sub-forum).
Thank you SkyeFire! I will check it out!
I also want to connect the automation but can not find where to connect please can tell something is missing
What is "pozhaluhsta"?
pozhaluhsta--- es ist please
You are welcome. -
I do not have any available I/O, what would be my next step.... Do I buy some I/O cards and install them (part number???) or do I have other options? Thank you so much!
Have you used all the I/O on the X11 plug?
If you have then you need a bus system, DeviceNet is the way to go as the KRC1 has DeviceNet on the MFC card so you won't need additional equipment on the controller.
I/O on the X11 plug? I did not know this, are all of the wires in the X11 plug available I/Os? Thank you!!!
I thought that the X11 plug was the safety circuit plug?
Some of the early KRC1s had a handful of hardware I/Os on the MFC that could be made available through the X11 plug, but I don't recall if that required an additional hardware option set or not. I never used them myself.
I believe that MFC I/O was eventually deprecated for later KRC1s, and KRC2s never had it.
All KRC1s that I've used have had I/O on the X11 controlled by the MFC.
16 in and I think 12 out, although I could be slightly wrong.
Check out the electrical drawings
It was one thing we missed when we started using KRC2, but luckily we always have a bus system as well.
Sent using Tapatalk 4.
