the time stamp in message box is not correct to current time. how can I change the system timing?
does KRC2 has system timing variable? we want to setup Counters that reset automaticly based on the time such as at 7am, 3 pm, or 11pm
Thank you in advance.
system timing
nguoimay -
June 7, 2013 at 6:45 AM -
The time stamps use the standard Windows clock.
Make sure you are in Expert mode and hit Ctrl+Esc (make sure the num lock is off!) to bring up the Start Menu.
