I have a Motoman sk6
He gives a error when you push the start button.
Error 0140 Can't start using P Box
What can i do?
Motoman sk6 error 0140 can't start using P box
menno -
May 28, 2013 at 9:55 PM -
Hi , first you need to establish how & what method you want this machine to "Start" , or has been
previously set to.
At present - if you go into "Play" on the controller "Play Panel - MODE "
then select "more" on the Pendant , you will see above F1 , COND 1 , using "SMALL-UP arrow", highlight
this box & press F1 , you will see list of options for Start" conditions , at present you have
(2) PPanel (PBox) - start Prohibit, Set "ON". -
Thank you, it works.
