how diffcult is it to modify the keystrings in an IRC5 controller, i know it will have to be a cold boot job, i want to add the pc interface option? can anyone give me a small discription how to do it? Cheers
Modify the keystrings?? IRC5 616-1 String!
DamoCollier -
January 15, 2013 at 10:17 PM -
Hello !
If adding options to the keystring,you will need to contact the local ABB office.
They have to generate a new keystring for you,updated with the new option.
And as you said, you will need to cold/reeboot the system.Dont forget to take a backup first.\PL
Ok, but how to do the cold boot job?
I already got the new keystring, now I need to load it to my controller.
ABB is taking a while to give me the procedure.
If someone can help, I will appreciate.Otherwise, when I have the procedure I will post it.
You need to do a X-start on menu ABB - Restart - Advanced - X-start OR C-Start.
BUT! First you need to backup your system.
X-Start - Don't erases the current system.
C-Start - Erase everything, only bootAplicattion, will remain on the memory.Then you use the system builder in the RobotStudioOnline
For how needs to update that on controller... just follows the instruction on this small manual.
This procedure is to use the robot studio.
Always backup all your system before do any change.
