Hello
I have a ABB S3 M92 IRB1500 robot and i have some problems with the software, because is in spanish language and is hard to understand. I want to install the english version but i dont have the controler software.
Please help !!!
Hello
Please help !!!
S3 was brilliant for changing the language. No need to install!
Just press the manual button (hand symbol) then SCAN (right hand soft key) three times until you come to a soft key with a * next to it (left hand soft key). That is the LANG key. Press that until the English language is selected.
If you need the programming manual send me a PM.
Hello
Send me please the programing manual and also the controler software if you have because i dont have it and maybe i will need.
The email address is shatza_yu@yahoo.com
The programming manual has been sent, you should get a link for the download.
The controller software is not as it is on S4 systems. The software for an S3 system is stored on a couple of EPROMS on the computer board. These were only supplied by ABB so if you need new version of software you would have to contact ABB although I doubt if they stock the EPROMS for this controller any more.
Why do you need new software?
If is to change the language you can do this quickly through the teach pendant.
prnuk2003 is correct, there is no need for software change with the ARLA programming interface. Manual-scan x 3 will locate the language settings. The language button will be the left button under the display. The S3 software is contained on EProms so getting replacement software is going to be fairly difficult. ABB may be the only place to find the EProms at this time. If EProms can be located they need to be copied (I don't believe there was any encryption back then) and installed on the Main CPU board. The IRB 1500 and the S3E control cabinet was only offered in 1992 and 1993. The IRB 1400/S4 system replaced the IRB 1500.
I have an ABB IRB 1500 but i d'ont have all the electrical components from the electrical cabinet. My task is to make it work but i d'ont know what is missing or how to connect the wirings. If i solve this problem maybe i will need the software or something...............
Now I am slightly confused - what is missing from the electrical components?
You have some control on because you want to change the language but it's going to be difficult to help with the rest your electrical issues as the detail is not specific.
Post a picture of the inside of your cabinet and maybe we can help that way. Also if you have power on let us know what errors you have.
This is my electrical cabinet
On the computer / drive system rack I can't see at first glance any ABB cards that could be missing (unless an I/O card has gone) but I also don't not see any wiring to the outside world other than the robot cables so I am not sure any process or external safety is connected to this cabinet . You have a very bare cabinet.
There are several blue cables cut/ disconnected to the left of the run contactor and I think that could be the break contactor that is missing (gap directly under the green I/O 1 terminal connector).
Have you any drawings at all?
Need to know what errors are you are seeing.
i have a contactor but i am not sure if is the run or the brake. I will try the put other contactor equivalent and to see where can i get 24 V for the contactors colis.
The first error that apears is 509 FALLO DE SINC 2101 and i saw that is not syncronize on the first axis.
I expect that the next message will be for the other 5 axes.
You will need to update the rev counters all together. Without the brake contactor you won't be able to drive the robot and this type of robot has a single brake release buttons so manually lining them up is going to be difficult.
If you need the manual drop me a PM.
Pleas can you send me the user manual for the irb 1500/s3c, i kind of make work the robot properly, but i don't know how to make programs and run them in an automatic way. Thaks for your reply
Manual sent
br prnuk2003
I also need the user or programing manual for Irb1500,S3 controller.Can anyone help me please?
thanks in advance!
Hi. I have a ESAB configuration for welding, which include a ABB robot IRB 1500/S3C M92/93. That machine is unused at last 10 years. I need some manuals, to see how it works. Can someone help me with anything?
gicovanubogdan@yahoo.com/bogdan.gicovanu@mecanicaceahlau.ro
Thanks!
Hola como están!!, alguien tendrá el esquema de conexión del robot a una fuente MAG esab o similar, quiero saber si me esta faltando alguna señal ya que no habilita la fuente de soldadura.-
Gracias (postventa@disprosol.es)
Welcome to the forum!!
Look at the M92 IRB1500 Service Manual found >here< in the manuals section.
Connections with the welder start on page 340.
Hope it has what you are looking for to get this old robot running again.
Hi Skooter, thank you very much for your response and interest, I'll see if we can get this ABB ahead. Greetings
