Hello, does anyone know where I can order the L axis gear seal for Ms 210
L-axis gear seal ms210
Rrafal13 -
April 25, 2024 at 11:03 AM -
kwakisaki
April 25, 2024 at 11:12 AM Approved the thread. -
Your local Yaskawa office.
Here is an example: -
ok, but yaskawa only sells seals together with the gearbox. they can replace the seal but as a service. I only need sealing
What is the part number you are looking for? The items I see have separate part numbers.
Numery na uszczelniaczu to 77AN-B oraz XE0999G.The L and U axle seal is the same.
I don't see that part number. Here is what I see assuming the robot is a standard -A0
This sealant is not included in the Yaskawa documentation. The sealant comes with part 2001.
So, you are looking for a chemical? Not an actual seal like your first post. The only chemicals on the L-axis would be grease, Molywhite or Vigo, and silicone, Threebond 1206C.
