Hi!
I have a problem while setup the 7 jit ( Robot carrier ) I hope to hear some advise from you guys
I using E-controller and trying to setup the Linear Axis(rovot carrier) with AC servo motor from SANYO DENKI
motor's Spec is 4.2 kW , 2400 rpm and model no. is P80B22450LCPUB
I was tying to follow external axis maunal but I can't find resolution values of this motor.
How can I find the resolution of this motor? or even if I didnt know the resolutin value from the beginning, is it a value that is automatically set?
following question : If I done the External Axis setting andthan should I have to setting the External Axis Servi Parameter ? if in this case, which would you recommend 1.Simple Tunning(Axis No.) and 2.Full Spec Tuning (Axis No.)
Thank you for reading
