Olá amigos, estou com um problema, temos dois robôs idênticos e um programa de limpeza de tocha, alguma linha foi editada ou excluída. Gostaria de saber se consigo fazer uma cópia de um para o outro sem fazer algum tipo de backup, ou com conexão via cabo ou via tp você poderia nos ajudar?
Copia de programa entre Robôs
Danilo Brito -
March 25, 2024 at 11:42 PM -
Nation
March 25, 2024 at 11:47 PM Approved the thread. -
Error E1079
This is an English board, please translate your posts in future.
Hello friends, I have a problem, we have two identical robots and a torch cleaning program, some line has been edited or deleted.
I would like to know if I can make a copy from one to the other without making some type of backup, or with a cable or TP connection, could you help us?
1.
If using AS save the program, locations, reals, strings, integers to a local medium file - SAVE/P/L/R/S/INT
If using BLOCK save the program only
Save to local medium:
- PCMCIA (if older controller.
- USB Memory if newer controller.
Load back into other controller and modify to suit.
2.
Otherwise make identical program save from both controllers.
Use Txt comparison application like WinMerge and locate different data and make same.
Then load back into controller.
Error E1079
You are attempting to use dedicated signal address in your code, this cannot be done.
Check Aux 0601, Aux 0602, Aux 0603 - Usually this is due to dedicated output allocation.
