Karel GET_TIME function question
  • Errorcode
  • March 25, 2024 at 10:05 AM
  • Errorcode
    24
    i have a question. I have some Karel program which creates some file with actual date in format 25-JUN-24 which works great.
    Name of file is created by script ,,file_name = SUB_STR(time_str, 1,9)" etc..
    I am making some upgrades and need to create other file which name will be just actual YEAR (in format 24.file or 2024.file). How to write it? I think i dont get it properly how that stored bits in actual time work.
    Thank you in advance :smiling_face:
  • hoitzing
    24
    128
    • March 25, 2024 at 11:10 AM
    I'd simply extract the year from the full datetime string since you only need the string representation (use SUB_STR like you did before).
    Otherwise it would also be possible to extract the integer value of the year since 1980 from the GET_TIME built-in. Like the documentation says the year is encoded in bits 31-25. So shift the entire value 25 bits right (divide by 2**25 and floor value to disregard the value in insignificant bits 24-0). Then this would give:
    year = ROUND(fulltime_int / 33554432 - 0.5) + 1980
    EDIT:
    With the latter method, of course you'd also need to convert the integer year value to string (CNV_INT_STR); which isn't necessarily difficult to do, but all in all it's getitng more complex than just extracting the year from the full string you already seem to have.
    Edited once, last by hoitzing (March 25, 2024 at 11:20 AM).
