Hello Community!
I am getting the following error on the stable's mcp upon powering on the cs8 controller.
Message <0x007> DRIVE-SensorNotReady: The Starc bus could not communicate with sensor because the bus for axis 1 is not synchronous [SYNCHRO bit]. (Please check Starc-Device Link and power shackes on device).
then we I hit ok and try to power on the arm via the start Botton, I get the following error:
Message <0x4001>
Arm power enable request refused: cabinet working mode is remote or invalid.
It seems like the Start cannot communicate with the Drive Sensors to establish connection and thereby powering up the arm.
the second LED on the Stark board is blinking slow which according to the manual means miscommunication with the DSI. Other LEDs blink normal. I appreciate if you could help.
