DX200: MOVL UNTIL ON... what if doesn't turn on?
  • CrazyHorse
  • February 15, 2024 at 3:10 PM
  • CrazyHorse
    Hello there to everyone
    My queston is very simple but yet a little tricky 'cause I don't have the chance to test it with the robot (for the moment).
    I have a palletizing robot which needs to measure the "high" of the pallet. In order to that there is a JOB to measure this high. So the gripper has a distance sensor -IFM O5D150- wich will be used as a discrete sensor: when the sensor gets the preset distance it becomes hi (1 or ON). Is there when I need that the robot stops the movement.
    Here's the code:
    SET B010 0
    *0102-1
    MOVL P011 V=40.0 PL=0 UNTIL IN#(5)=ON
    IF( IN#(5)=OFF AND B010<2 ) THEN
    INC B010
    JUMP *0102-1
    ENDIF
    I'm using this IFTHEN to give a row of tries before continuing to the next step of instruction.
    But my question is: what if the sensor -for whatever reason- never turn on?
    How much time or movement the instruction MOVL will go 'till execute IFTHEN?
    Or the robot will go to P011 'till the end?
    Hope I was clear with the point
    Best regards
    Lucas.
  • HawkME February 15, 2024 at 3:40 PM
    Approved the thread.
  • roboprof
    24
    464
    • February 15, 2024 at 3:42 PM
    If the input never comes on, then the robot will complete the move (go to P011).
  • CrazyHorse
    • February 15, 2024 at 4:09 PM
    Quote from roboprof
    Thank you
    I'm a newbie. I'm learning and these are my first projects. Sadly, very few chances to test in time the lines of code that I'm writing.
  • until
  • MOVL
  • IFTHEN
  • MPL100-II
