HI all,
I am using an old MRC controller for the SK120 and I have it connected to a PLC. When the power is turned on (or if the PLC is reset) the PLC will enable remote mode via the connections to the front panel then after 5sec (or something close to that) it enables the servo input pin to switch on the servos. It was working fine for a while but this week it has now started displaying "Action prohibited by external device" on PP when the Servo input is enabled. Any help with diagnosing what is causing this would be great.
To preempt, the External Servo pin does not appear to be disabled in the COND menu (though it is worded awfully so I could be wrong) and I am sure remote mode is properly enabled before I try and set the servo to on
