High Speed Ethernet Client YRC 1000
  • SergioJulio
  • December 22, 2023 at 12:25 PM
  • SergioJulio
    5
    Hello Guys,
    I am using high speed ethernet client dll to build an c# app with robot. I wrote an exemple from the yaskawa manual just to start understand how it works and did all configs needed on the robot.
    I change values from byte variable in pendant to whatch in visual studio, but nothing appears.
    Any idea?
    i can send photos of the code and of the robot configs to check
  • MOM December 22, 2023 at 12:53 PM
    Approved the thread.
  • TSGIR
    81
    715
    • December 22, 2023 at 9:53 PM
    Hi
    Please send me your VS code.
  • SergioJulio
    5
    • January 2, 2024 at 12:11 PM
    VS acode above.
    I follow yaskawa example. Maybe the VS code is ok and only need change some parameter on robot controller.
    please, check.
    TSGIR type your email and i can send to you yaskawa manual or other information to help me solve this problem.
    Tkanks
    C#
    using System;
    using System.Collections.Generic;
    using System.ComponentModel;
    using System.Data;
    using System.Drawing;
    using System.Linq;
    using System.Text;
    using System.Threading.Tasks;
    using System.Windows.Forms;
    using HSEthernet;
    using System.Net.Sockets;
    namespace Teste_2
        public partial class Form1 : Form
            int status;
            HSEClient HSEC;
            public Form1()
                InitializeComponent();
            private void Form1_Load(object sender, EventArgs e)
                int valteste = 1;
                //int y = 2;
                HSEClient H = new HSEClient("110.150.100.10", 200, 2);
                byte[] Bytes;
                HSEClient.RecStatus RS = H.B_Read(0, 10, out Bytes);
                //label2.Text = ($"{y}");
                label2.Text = RS.ToString();
                if (BitConverter.IsLittleEndian)
                    Array.Reverse(Bytes);
                int x = BitConverter.ToInt32(Bytes, 0);
                label1.Text = ($"int: {x}");
  • Caj
    • November 26, 2024 at 10:19 AM
    Hi.
    You can access your B-variables directly from the Bytes array, where Bytes[0] holds the value from B000 since your starting point is 0. Try it something like this:
    HSEClient.RecStatus RS = H.B_Read(0, 10, out byte[] Bytes);
    label1.Text = Bytes[0].ToString();
  • High speed Ethernet
  • YRC 1000
