CS9 controller with a tx60 robot
Symptom is that when the robot is in motion it may fault with "DSI9 board not referenced error". If you redo the safe reference it completes that no problem. I have done some preliminary checking of the wiring harness in case this is a ground issue causing the controller to fault. There were a couple of loose wires. These have been resolved and we are still reproducing the not referenced error.
Below is the fault displayed in the log. I have already contacted Staubli, but the clock is ticking. Any help would be appreciated.
